Steering Knuckle Arm Rivet - NCRS Discussion Boards
  • Allen N.
    • January 1, 2003
    • 288
    The steering knuckle arm has two holes. Power steering cars are supposed to have a rivet in the rearmost hole. Does anyone know where I can purchase two of the 3794056 rivets or two rivets that closely look like them? I have looked at several of the Corvette vendor websites and have not been able to find them.
    Allen
  • Gary R.
    • April 1, 1989
    • 1796
    Re: Steering Knuckle Arm Rivet
    Hi Allen
    I think I bought those aluminum plugs from Brian Bair in the past.
    • Allen N.
      • January 1, 2003
      • 288
      Thanks Gary.
      I'll give Bair's a call tomorrow.
      • Gary R.
        • April 1, 1989
        • 1796
        Allen,
        If Bairs don't have them check with Jeff Pollard here on NCRS, I did his front arms a few years ago and he supplied them. I recall this because I installed them in the wrong position as the factory did- they functioned correct but appeared wrong!!!!duh! Jeff can help you.
        • Ron G.
          • December 1, 1984
          • 865
          Allen - There are plenty of good used ones around which you might want to consider. This way you are ensured of getting the correct configuration and style of rivet.
          - Ron
          "SOLID LIFTERS MATTER"
          • Ed D.
            • December 1, 1990
            • 329
            I believe the power steering hole is the ones closest to the front not the rear, the manual steering goes in the rear hole
            Ed
            Sorry I misread, I was referring to the tie rod end in the front hole for power steering,
            Ed
            Ed DiNapoli
            CNJ Chapter Past Chairman/Co Founder
            1972 Targa Blue Coupe, Original Owner,
            Duntov Award, Sam Foltz Award,
            Founders Award, NCRS Gallery VIII
            2011 Corvette Convertible
            NCRS Presidents Award 2014
