Would someone be so kind as to post up a picture of the correct location for the Harrison foil label on the evaporator box. Thanks in advance.
'67 foil plate for evaporator box location
Re: '67 foil plate for evaporator box location
Leif,
After much research , here is what I figured for my mid to late 66. Should be the same .
JimAttached Files- Top
Great pic Jim...thanks. So, once the evaporator is installed, the supply tank pretty much covers up that area. Removal of the supply tank appears to be the only way to install the foil label. Thanks, again.Leif
Top Flight 2017 Lone Star Regional- Top
I had to go look at mine to be sure , but yes , it is directly behind the expansion tank when installed.
Still , removing the tank looks easier than doing it the way I did !
Jim- Top
