My parts manual states a MC code for all
Radiator Build Sheet Code - 74 BB 4 spd Convertible
Re: Radiator Build Sheet Code - 74 BB 4 spd Convertible
Same thought here. There could easily be 4, but there were at least 2 different ones as Russ mentions.Vice-Chairman (West), Michigan Chapter NCRS
M3 is the date code. Big block and small block used the same radiator in 73 so I would expect there to be only the two different codes. One for 4spd and the other for automatic with the cooling provisions.- Top
Ok – thanks for clearing that about additional codes other thanMC. I’m assuming the MD code on my build sheet then is for 74 BB radiators withA/C and manual tranny since those options are also listed on my build sheet andin on my car.
Like I posted before - Harrison is embossed on the passengerradiator side. Under that there is another embossing – it reads M 3. Since the 74 radiator tags only showed the part number and a two letter code I’m assuming the M 3 embossed on the radiator side is a radiator build date of 73 maybe? Just a guess.
Thanks for your help.
Victor-----
MC= radiator for applications with oil cooler (i.e. THM equipped) GM #3030199
MD= radiator for applications without oil cooler (i.e manual transmission) GM #3030132In Appreciation of John Hinckley- Top
I keep an inventory of buildsheets, actually 73-82 GMAD manifests and have several from 1974. During that period, higher cooling capacities were required for A/C, THM 400 and LS4s. Another code I see used in 1974 is MA installed on L48, M40 but no C60 (A/C). MA is also used on an LS4, M40 and no C60.
The MC code is used on L48 M40 and C60. I have a couple of manifests that show this combination.
The MD code is used with L82, M21 & C60
And to muddle the code use further, I have another 74 manifest and it appears to be an MG with options, L82, M21, non-C60 car.
That makes four!Tom Russo
78 SA NCRS 5 Star Bowtie78 Pace Car L82 M2100 MY/TR/Conv- Top
