The first was trying our CA 91 octane when I ran out of my mix of 91 and avgas. I only let the engine warm up and moved the car with low power loads to keep it from pinging. When I turned the ignition off the engine dieseled so I turned the ignition back on and the engine ran again. The car has a automatic trans in it so after trying 3 more times I turned the air on, lights, and put it in reverse and it shut down. That one cost me a piston skirt so I stored the car until I could pull the engine that had less than 2 K on it.
Put avgas in it and the engine ran great except for the piston knock. Went to move the car and it was out of gas so I suckered into the second mistake. I poured pump gas in it to get it back in the shop and: With the starter turning the flywheel in the correct direction, the engine fired backwards because of the flame rate and took out the starter drive.
It's a 425 BB automatic that I tuned to factory specs. I did de-tune it once to see how it would run on pump gas but was dissapointed in the lack of performance, the reason I had the 425/427.
No 3rd time for me.
Dom
No 3rd time for me.
Dom
