C2 dash lights - NCRS Discussion Boards
C2 dash lights
  • Randy R.
    • March 1, 1983
    • 477
    C2 dash lights
    The dash lights on my 67 convertible seem dim so I removed one bulb to check the voltage. It was 10.6. The voltage at the battery was 12.1. The engine was off. The bulbs are original. I suspect a problem with the headlight switch. What do you think?
    Thank you.
    Randy
  • Keith B.
    • September 15, 2014
    • 1575
    Re: C2 dash lights
    Did you rotate the headlight switch knob back and forth?
      • 6940
      Re: C2 dash lights
      Thank you.
      Randy
      Randy, I have seen this issue before and what I find is the after market switches do not have the same voltage output at the rheostat.
      • Randy R.
        • March 1, 1983
        • 477
        Re: C2 dash lights
        The headlight switch is original. Is it possible that the voltage drop is due to a dirty switch?
        Thank you,
        Randy
        • Patrick C.
          • January 16, 2013
          • 327
          Re: C2 dash lights
          I recently took my original headlight switch out of the car and disassembled it. I cleaned it throughly with Deoxit D and reassembled it. It made a difference in the brightness of the dash lights.
          • Randy R.
            • March 1, 1983
            • 477
            Re: C2 dash lights
            Thank you for the replies. I removed the switch and cleaned it. The lights are now brighter.
            • Frank D.
              • December 27, 2007
              • 2703
              Re: C2 dash lights
              DeOxit is what you want to use for such things....a good shot in the harness connector as well as the headlight switch should help..
              • Bob W.
                • December 1, 1977
                • 799
                Re: C2 dash lights
                Frank, Have you ever used CRC QD Electronic Cleaner? The can states clean and protects sensitive electronic equipment.
                Bob
                • Frank D.
                  • December 27, 2007
                  • 2703
                  Re: C2 dash lights
                  Bob
                  I have not....I stick with the DeOxit - its all I use for 'contact cleaner'...
