Stainless window chrome restoration - NCRS Discussion Boards
  • Garth T.
    • January 24, 2018
    • 20
    Who is the recommended source for window trim and other stainless restoration?
    Thx,
    Garth
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Stainless window chrome restoration
    Where are you located ?
    • Gene M.
      • April 1, 1985
      • 4232
      Most of the trim is chromed stainless. A simple buffing on a wheel and polish makes it new looking again . If you spend more time on the buffer it will look far better than it ever did when new.
      • Jim D.
        • 2882
        I just polished all the stainless trim for my 65. The difference is incredible. The before and after are like comparing brushed aluminum to fresh chrome plating.
        • Garth T.
          • January 24, 2018
          • 20
          • Frank D.
            • December 27, 2007
            • 2703
            Originally posted by Garth Thompson (64361)
            I’m in Alaska. So someone on the West Coast would be preferred.
            Then my guy in Florida wouldn't work probably - he's incredible.
            • Garth T.
              • January 24, 2018
              • 20
              Pass on the info Frank, it could still be helpful. thx!
              • Gene M.
                • April 1, 1985
                • 4232
                It sounds like he does not want to polish it himself. He wants somebody else to do it.
                • Garth T.
                  • January 24, 2018
                  • 20
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    J & M stainless steel repair in Bunnell 386-445-7032 cell 569-9631
                    The guys name is John Marques
                    I've polished some larger pieces myself with good results....the thin curved piece around the split window rear glass is another thing altogether. The shape doesn't really lend itself to affixing it to a board for polishing (like C1 cove molding) and its fragile, expensive stuff.
                    I'll let a pro do that...
                    • Garth T.
                      • January 24, 2018
                      • 20
                      • Keith W.
                        • June 30, 1998
                        • 375
                        Picked up some great re worked hub caps off this guy - Victor Gomes 386-864-0587
                        11 hargrove grade unit G Palm Coast Florida
                        vrmlgomes@yahoo.com
                        • Richard G.
                          • July 31, 1984
                          • 1715
                          I highly recommend Jim Lemans
                          Located in Kelso WA 98632
                          jimlemans@msn.com
                          He knows how important it is not to overheat the stainless window moldings to keep them from warping.
                          Jim is also a wizard at removing the dings and dents.
                          Rick
                          • Garth T.
                            • January 24, 2018
                            • 20
                            • Mike E.
                              • February 28, 1975
                              • 5134
                              Actually, he's on the left coast.
