Hi, I just check both of my 95 ignition keys and do not see any stamp on the metal key side indicating either D or H keyway. Manual says it should be there. The are no close up photos in the manual. If anyone could help I would appreciate it.
95 LT1 Coupe - Ignition Key Stamp D or H
Re: 95 LT1 Coupe - Ignition Key Stamp D or H
Chris,
My 1990 C-4 has the" D" on the door, glove box key. The Ing key (w/pellet) has no stamping. However if you have the knock-out for your Ign. key
there is a stamping on the knock-out that indicates a code for the pellet. Many times the dealer knocked it out My code for the pellet knock-out is 7310. Hope this helps.- Top
Ditto for my 96.Attached Files- Top
Dave, my born-with "pellet keys" do not have numbers on them as you describe.Originally posted by Dave Perry (19643)I know I've seen "pellet keys" with a 2-digit number, not a letter. (In about the same position as the letter is on Pat M's round key pic above). The number represents the resistance value of the pellet. Do ya'allz born-with ignition keys have a number on them? Or was I looking at key-shop pellet keys?- Top
Dave,Originally posted by Dave Perry (19643)I know I've seen "pellet keys" with a 2-digit number, not a letter. (In about the same position as the letter is on Pat M's round key pic above). The number represents the resistance value of the pellet. Do ya'allz born-with ignition keys have a number on them? Or was I looking at key-shop pellet keys?
Son’s 1996 does not have 2-digit number on pellet key.
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
