I am replacing the lower bearing, and I have some unidentified parts (at least to me). After combing through the archives and reading numerous threads, I am still without a definitive answer as to the relationships of some column parts. The column in question is out of a June car, so it is the late design at the lower bearing. I have determined that the lower bearing was also used in the telescoping columns and standard columns in both '67 and '68. Depending on the vendor, they show different replacement bearings, but both needle and ball styles are available. My question involves a spacer that I do not have information on concerning its placement in the column housing. It is not the spacer at the bottom of the shaft between the clamp and the lower spring and bearing. It came out with the shaft and was loose. There was also some remnants of what looks to be a felt or similar material that looks like it was some sort of packing, but I have no clue as to what it was. This is a standard non-telescoping column. I am including some photos. The first is the lower bearing and the spacer in question. The second is the shaft and approximately where the spacer was on the shaft as well as the material that came out. If anyone has information on where these items actually belong, I would be genuinely appreciative. If necessary, I have additional photos and can take more.
Steve
Steve
