C2 Engine Compartment Htr Box Cover Sealant - NCRS Discussion Boards
  • Joseph S.
    • October 27, 2014
    • 187
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 Engine Compartment Htr Box Cover Sealant
    The deduction was done without merit. Understand the sealant for the heater box was ONLY DONE TO CARS THAT LEAKED WATER TEST. This application was NOT part of the normal production line process. It was only performed on cars that leaked as a fix.
    Be aware that not all judges have the same level of knowledge and miss calls are apt to happen.
    • Harry S.
      • July 31, 2002
      • 5258
      Gene is correct. Leave you car as is. If you do add the sealant be prepared accept the fact that you may break the cover trying to remove it.
      I've had my 63 judged several times and no deductions for lack of sealant.
