It's the "trigger plate" (housing) for an old Smith and Wesson 916-A 12 ga. shotgun. A few years ago I was disassembling it for cleaning and the bolt that holds the stock to the trigger housing was seized, and when it finally broke loose it was the die cast trigger housing that broke.
I've searched periodically for a replacement, but no luck; gunpartscorp.com lists part numbers for both the bare housing and complete assembly, but they say none are available and the only chance is if they get hold of used or NOS, so at this point it's probably a long shot, and I've replaced it with a more modern piece.
I like the traditional look - wood stock and pump grip, and I'd like to put it back together for "display only", so I want to repair the trigger housing so I can at least lightly fasten the stock back on and hang it on the wall above my fireplace. I will also disable it by removing the firing pin and disabling the pump action as it would be unsafe to fire.
The only thing I can think of is Superglue, but do any of you guys have any suggestions or experience repairing broken "pot metal" die castings.
