I am getting ready to install power steering to my 65, 327/300. Kit arrives Monday . I went ahead and removed the relay rod with tie rods still attached. Once I was finished I realized that the I moved the spindles in removing the relay rod and the tires were no longer pointing exactly straight ahead. I reinstalled the assembly, got the tires pointing straight ahead and then took a measurement from one tire to the other, then once again removed the relay assembly. My question is, will installing the new relay rod and attaching the tie rod ends using the measurement I took be close enough so I can take it to get the front end aligned? I also noticed that I'm going to need to adjust the tie rod ends to get them to fit in the forward holes on the spindle. I think I'm ok with what I did but would appreciate confirmation or any suggestions. Thank you.
Bill B.
Bill B.
