Who is doing drive shaft and half shaft restoration to NCRS standards? Thanks, Bill Gould
Driveshaft and Half shaft restoration?
Tags: None
- Top
Re: Driveshaft and Half shaft restoration?
i believe Mike Zamora is doing them. They look great from what I have seen. If you are on any sort of budget you might need to consider another option.- Top
Bill, contingent upon what engine is in your Corvette, ( all from 1965 through 1972) if it is fuelie, 365, big blocks, LT-1 they had their hot shafts shot peened to relieve the stress of their welds because of the torque of the high-performance engines. They were shot peened with a number (31) shot. I know of a company in east Hartford, CT that does a great job."SOLID LIFTERS MATTER"- Top
Ron,
Were the half shafts in base engine, automatic transmission cars shot peened also? Our JG states that base engine cars used U-bolts to fasten the half shafts to the differential yoke but I know for a fact that base engine/automatic 1971 and 1972 cars used the blocks just like the BB's and LT-1's.
The half shafts in my base engine/auto car look identical to my LT-1.
I suspect these were shot peened but I'm curious if you know for certain?
Mike- Top
Dave------
I don't think anyone could restore the exact original finish of any Corvette driveshaft or non shot-peened half shafts.In Appreciation of John Hinckley- Top
Mike-----Ron,
Mike
1968-74 base engine cars used non shot-peened half shafts, manual or automatic transmission.
1969 L-46 and 1970-72 LT-1 MAY have used shot-peened half shafts; I can't confirm but I suspect that at least LT-1 did use shot-peened shafts.
1973-74 L-82 used shot-peened shafts.
Is it possible that any particular Corvette scheduled to receive non shot peened shafts actually received the shot-peened avriety? Of course.
Stub axle type (cap or u-bolt) is related to the installed differential carrier assembly and unrelated to the type of half shaft used.In Appreciation of John Hinckley- Top
1969 to 1972 M40 were supposed to get shot peened (with cap) half shafts. I think 1968 falls in there also, but I am not so sure of that. Of course, as Joe points out, they would have the HD differential.Terry- Top
Terry------
I'm not so sure. If you look at AIM sheet M40-A2 for 1968-72 you will note no reference to "differential and axle shafts". This implies that they are the same as production. (You will note such a reference for 1970-72 LT-1, though).
For 1973-74 the axle shafts installed differed only as a result of installed engine. L-48, regardless of transmission, received the non-shot-peened axle shafts; L-82 and LS-4, regardless of transmission, received the shot-peened axle shafts. I don't see why it would have been essentially any different for 1968-72.
Of course, with respect to any particular car, could shot-peened shafts have been originally installed instead of the standard variety? Of course. Such an upgrade probably wouldn't have even required engineering approval.In Appreciation of John Hinckley- Top
Joe,
Believe it or not, I actually have a little over 5' of what I believe is NOS drive/half shaft tubing. As you are probably aware, 71's had a larger diameter tube for the drive shaft than the 70's. The half shafts I believed used the same diameter as 1970."SOLID LIFTERS MATTER"- Top
Ron-----
1963-70 driveshafts, except 1968-70 with M-40, were, nominally, 2" OD.
1968-70 driveshafts with M-40 and all 1971-79 were, nominally, 2-1/4" OD
1963-74 half shafts were, nominally, 2-1/2" OD
1975-79 half shafts were, nominally, 3" ODIn Appreciation of John Hinckley- Top
I think I'll shot peen one half shaft and leave the other plain. Just kidding.- Top
My observations are from looking at a whole bunch of Corvettes, but I haven't seen all of them; and I am pretty sure I won't live long enough to see them all, but I'll try.Terry------
Of course, with respect to any particular car, could shot-peened shafts have been originally installed instead of the standard variety? Of course. Such an upgrade probably wouldn't have even required engineering approval.Terry- Top
Terry-----
By the way, only the shot-peened half shaft was available in SERVICE from March, 1966 thru 1974. After that time, only the 1975+ half shaft was available for all 1963-74 SERVICE.In Appreciation of John Hinckley- Top
