Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Driveshaft and Half Shaft Weights -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I bought a new driveshaft and half shafts through Zip Corvette. They seem to be of high quality, but there are no external balancing weights on them. I don't know who their vendor is and the sales kid is no mechanic. I've never seen a shaft on any type of car that didn't have a weight on it, but I don't work on/pay attention to the new stuff ( meaning anything newer than 40 years old, lol.) I've had several custom drive shafts built for me over the years for drag cars or street rods. My question is: Is the technology now such that shafts can be built true enough that no external weights are required, or did I get shafted? A google search on this subject was shall we say, "inconclusive." Obviously, I can haul them 60 miles to the nearest drive shaft shop and have them checked, but I would like to learn a little more first. Judging points are a separate issue. Thanks.
I think your concern is a valid one. Chevrolet lists at least 5 different weights that are welded on "as required" . For a driveshaft, prints state: "Paint no. 248-0679 yellow or equiv. opt 248-59863 light green or equiv. marking to be at rear of tube next to nearest exposed trunion and as close as possible to light side at rear of assembly when balanced" Further instructions noted: "max. run out of assy. at points A,B,&C to be .010 TIR Assembly must be within 3/16 in. oz. dynamic balance at front end and .10 in. oz. at rear end when tested at 3500 RPM." Further notes are listed but you get the idea. Without looking at half-shaft specs. I would venture a guess they would have similar specs. Maybe new technology no longer requires this method to balance but I would be leery.
... Without looking at half-shaft specs. I would venture a guess they would have similar specs. Maybe new technology no longer requires this method to balance but I would be leery.
David,
I have never seen a half-shaft that had balance weights, which makes me think there was a runout and balance tolerance included as part of the basic manufacturing process and not done via added weights.
It is easy enough to find out.........have the driveshaft house check them out for balance, true, and straight.......why guess.
Because maybe I'll spend more money having a drive shaft shop screw up something that aint broke to begin with. Like I said - trying to learn more about the manufacturing.
Because of the driveshaft speed and length it should be balanced. The half-shafts don't really require them (per GM's on specs) because they are short and run typically at 1/3 the speed of the driveshaft. The unbalance is not a liner force but is exponential so this is a big difference in forces.
Back to the drive shaft, their is a run-out specification and a balance specification. Hitting both these specifications is almost impossible without weights. Some shops send a spec sheet with the shaft.
The residual run-out is often dealt with by heating and spot cooling the shaft to get it withing specifications. This is after the shaft is built and typically when it is installed in the balancer as it saves a step. The shaft balance also accounts for any residual unbalance left from the small amount of run-out that has to still be there. Could they hit this specification on a random basis, sure. Is it likely, no. I would have the balance and run-out checked at the nearest drive-line shop. Let us know what they find. A shaft balance it typically not that expensive. Document it and possibly you can negotiate an reimbursement from the manufacture. This is the exact same stuff I dealt with when I worked as a Vibration Analyst for 21 years.
Rick
Rick
Richard, thank you for taking time to share your obvious expertise in this area. Very informative. It will be some time before I get to it, but I will have it checked and report the findings.
You stated “I've had several custom drive shafts built for me over the years for drag cars or street rods. My question is: Is the technology now such that shafts can be built true enough that no external weights are required, or did I get shafted? A google search on this subject was shall we say, "inconclusive."
Well, did they screw up those drive shafts? Your response in post #10 was acceptance of advise already given much more wordy but same, and you previously rejected it. What better place for enlightenment than where the task is performed? Go figure.
Rick.
Rick------
The driveshafts were originally balanced as an assembly with u-joints installed. That's why when u-joints are replaced the existing weights are "meaningless". I recommend having the u-joints installed by a competent driveline shop and have that shop subsequently balance the assembly.
