Fuses and issues - NCRS Discussion Boards
Fuses and issues
  • Joe T.
    • February 25, 2018
    • 153
    Fuses and issues
    If you have recently purchased an older Corvette, you may want to check for correct fuses even if it had a body off restoration. I have a 1966 427 425HP that had a body off restoration prior to purchasing it. The manual calls for one 15 amp, three 10 amps, one 4 amp and one 3 amp. The car had four 25 amps and two 20 amp fuses in it. Looks like the guy purchased a box of 25 amp fuses. I had an issue with the rear courtesy light. The attached photo will identify what the problem caused. I have since then installed correct fuses and/or replace/checked/repaired all my wiring. Just identifying my experience.
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Fuses and issues
    Not good!!!!!!!!!!!!!!!
    • Donald O.
      • May 31, 1990
      • 1580
      Oh my gosh!!!!!
      You let the smoke out of the wires!!!!!
      Seriously though, I'm glad you found the root cause before a total loss from fire.
      Don
      • Edward B.
        • January 1, 1988
        • 537
        Not relative to fuses, but thanks to Joe for using the proper term, "body off restoration," rather than the meaningless, "frame off."
        • Dick W.
          • 10483
          Originally posted by Donald Olson (17357)
          Oh my gosh!!!!!
          Don
          Dick Whittington
