Trying to get my 78 PC back to factory. The previous owner swapped out the L82 Air cleaner to one that is on an L48. I have found the correct double snorkel air cleaner and mos of what is needed but cannot locate the front side of the air duct that the left side snorkel attaches to. Have the right side and they are plentiful but cannot locate the left side. Any clue where I canget one?? DOn't really know the technical name for the part! As always..thanks in advance.
air duct
Re: air duct
Chris
Several vendors should have your part. These folks are at Carlisle every year and I purchased my air cleaner parts from them.
http://keenparts.com/CorvettePartsDi...&diagram=10011
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
Re: air duct
Chris------Trying to get my 78 PC back to factory. The previous owner swapped out the L82 Air cleaner to one that is on an L48. I have found the correct double snorkel air cleaner and mos of what is needed but cannot locate the front side of the air duct that the left side snorkel attaches to. Have the right side and they are plentiful but cannot locate the left side. Any clue where I canget one?? DOn't really know the technical name for the part! As always..thanks in advance.
If you are talking about the FLEXIBLE "hose" that connects the air cleaner snorkel to the forward plastic duct, it's called a FLEXIBLE DUCT. The left (driver) side is the same for both L-48 and L-82. It was GM #368684. It's discontinued but available in reproduction.In Appreciation of John Hinckley- Top
