Good Evening. I just purchased a 71. When you first start the car the battery gage shows a slight positive and drops to zero or slightly below. Using turns signals you can see the gage go negative slightly with each pulse. When you turn on the lights or air it drops like to -15 regardless of revs. It does seem to read differently as to how negative on the same item each time you turn it on.
I put my meter on the battery and it read around 12.6 with everything off. Upon starting and running it shows slightly over 14 volts. This is true even turning the lights and the air on at the same time. The meter will show over -20. Do I have a bad gage or a ghost somewhere?
It scaring the hell out of me when I look at that gage.
