How to adjust rear drums on a positraction car - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 660
    I am adjusting the brakes on my 1960 positraction car. My question is how do you adjust the rear drums? The ST-12 says to turn the star wheel while rotating the wheel until you get a light uniform drag then back off the star wheel. This works just fine on the front wheels but I can barely turn the rear tire by hand as turning the wheel also rotates the opposite tire and moves the driveshaft through the rear axle. How in the world are you supposed to adjust the rear drums when the wheels don't turn freely?
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Terry D.
    • May 31, 1987
    • 2690
    Re: How to adjust rear drums on a positraction car
    Keith
    You could try disconnecting the drive shaft and see if wheel is easier to turn. I'm guessing that the weather is warm were you are at. Make sure emergency brake is releasing all the way. Have you pulled the drums and checked the shoes and drums for high spots? Wheel should not be that difficult to turn with a posi. Having another person turn the wheel is another option. Do both wheels have the same resistance?
    • Keith B.
      • September 15, 2014
      • 1575
      Can’t you back up very quickly and slam the brakes?
      • Mike M.
        • May 31, 1974
        • 8365
        c-1's don't have self-adjusters like the 63 and 64 corvettes.mike
        • Keith B.
          • 1575
          Thanks Mike. I did not know that and that is how I was taught to adjust drums.
          • Mike M.
            • May 31, 1974
            • 8365
            keith: your method works great on c-2's with drum brakes if bubba hasn't removed the self adjusting features. regards,mike
            • Keith R.
              • August 31, 2001
              • 660
              Thanks Dave. That's certainly a viable method. I was just thinking of expanding the shoes until the star wheel doesn't easily turn further then backing off 12 clicks.
              Keith MacRae
              NCRS #36692
              New Mexico Chapter
              1960 290HP FI
              • Keith R.
                • August 31, 2001
                • 660
                Thanks Terry. This is a new build with all new drums, brake cylinders, shoes, hardware etc. and has not been driven yet. The parking brake has been backed off until it is loose and it is still difficult to turn the wheels by hand. Yes, both wheels have the same resistance. I was also thinking that I could disconnect the drive shaft to allow it to turn more easily.
                Keith MacRae
                NCRS #36692
                New Mexico Chapter
                1960 290HP FI
                • Keith R.
                  • August 31, 2001
                  • 660
                  Found the problem. See my 7/7/18 reply to Thomas Hoyer's post regarding the same issue.
                  Keith MacRae
                  NCRS #36692
                  New Mexico Chapter
                  1960 290HP FI
