67 carpet passenger footwell - NCRS Discussion Boards
  • Kerry A.
    • August 31, 2004
    • 152
    Does the carpet in the passenger side foot well go up butt the foam heater box gasket or does it go over the foam gasket and butt to the bottom of the heater box at the firewall? Thank you
  • Peter M.
    • May 30, 2013
    • 358
    Re: 67 carpet passenger footwell
    Kerry,
    If you search for "another carpet install question" you should find a thread started by Jim Schwering on Nov 18 2017 with several photos.
    Sorry I can't make the shortcut to the thread work.
    Kind regards,
    Pete
    • Kerry A.
      • August 31, 2004
      • 152
      Pete, You were dead on about the search. I found the pics. Exactly what I needed to see. It was a perfect view. I'm installing new carpeting and the area around the heater box was a head scratcher. I installed that area as shown in the pics so I believe it's correct. Thank you for your help. Kerry
