67 L-71 dies out after 10 min running - NCRS Discussion Boards
  • Tom B.
    • March 1, 2002
    • 140
    I have a 67 L71 it starts fine runs about 10 min then dies. Its not fuel . looks like it has a re-man TI Box. Checked connections didnt find anything. Any ideas?
  • Steve B.
    • March 1, 2002
    • 1190
    Re: 67 L-71 dies out fter 10 min running
    Check your coil.
    • Dick W.
      • 10483
      Coil or TI amp
      Dick Whittington
      • Keith B.
        • December 1, 1991
        • 397
        I have had the same issue years back and found it to be that when the oil inside the coil heated up the motor would stall; once the coil cooled back down it would run fine again.
        Keith Burmeister
        • Ron G.
          • December 1, 1984
          • 865
          Tom - I know you said that it is not Fuel, but What about the fuel filter? One of my cars would run for a very short while and then shut down. I thought it was worth mentioning.
          "SOLID LIFTERS MATTER"
          • Mark L.
            • 550
            Tom, I had that problem with an L-71 and it turned out to be the distributor coil. Failed when it got hot. However Ron's suggestion is also a good one as fuel filters or rubber lines can create starving. Good luck.
            • Ken A.
              • July 31, 1986
              • 929
              Not with an L-71. It's almost impossible to plug up a Holley filter. It should IDLE all day. But, high RPM operation is another topic.
              • Wayne L.
                • September 30, 1981
                • 233
                A fellow Chapter member had a similar problem with a 66 big block. Found the repro distributor cap was faulty.
                FWIW
