Hello all,
I am the PROUD new owner of a beautiful Panama Yellow/White 1958 Corvette, and new to the NCRS web site.
The car came down from up north last month to Florida. After two short drives, the radiator started leaking. Found out someone put sealant in the radiator to stop a leak along the way. Disappointed on many fronts....yup. Especially not being able to drive this bucket list item.
Here's my question, if I want to keep the car up to NCRS standards, high 90's, and change out the original radiator, would I loose points if I used the Dewitt black radiator in the car when it's judged? This assumes all the stickers and manufacturers tag are reinstalled. Is there a better alternative for a OEM radiator I should consider? Also considering a re-core of the original radiator. Suggestions?
Thank for the insight and help
Solid Axle Newbie.
Solid Axle Newbie.
