1957 Ballast Resistor - NCRS Discussion Boards
  • Salvador B.
    • May 11, 2008
    • 50
    Is the ballast resistor supposed to get hot when the ignition is on?
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 1957 Ballast Resistor
    yes the BR will get warm once the ignition switch is in the run and crank mode on a 57. its purpose is to reduce the voltage to the + terminal on the coil to 6 volts. mike
