1963 Headlight Wiring Harness Clip and Retainer Measurements - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 398
    Routing of headlight harness wiring from firewall to front of fender:
    The Assembly manual shows a clip that is bonded to the underside of the fender, followed by the first hole/retainer location that is 10 Inches further down (towards the front of the car). It does not show the location/distance of the clip from the firewall, nor the distance between the first hole/retainer and the next two. I have looked at photos on the web but some of them vary and would like to get the holes for the retainers in the correct locations. This is a replacement inner fender from early '70's, hence the need to get the correct measurements.
    Thanks in Advance,
    Fred
    • 6940
    Re: 1963 Headlight Wiring Harness Clip and Retainer Measurements
    Fred the pass side fender has early and late as the harness and surge tank hose have different routing, we'll want to know the month of production or some of the VIN numbers. The drivers should be the same for all 63.
