Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
On page 112 of the TIM/JG the following statement is made regarding carburetor mounting studs: " Stud tips may also be painted orange." Please comment on the following:
1) Does the above statement only apply to studs used in cast iron intakes? In other words, if there is orange paint found on the stud tips, it got there when the intake was painted orange.
2) The orange paint on the stud tips is an inspection mark and is found randomly on all engine models.
3) The orange paint on the stud tips was sometimes put there by the manufacturer of the studs.
If it were a inspection mark it would likely be only one stud with paint on it. JG says "studs" which would likely be paint from painting the intake manifold.
If was part of the intake spray it would of been along on lower section of intake up to the intake bolts, but there talking small orange tab on top of each studs , see the photo 112 113 look at the Carburator studs there a tab of orange paint on the studs not a spray.
didn't Flint have the engines hanging on a over head crane system and the engines had a plate on the carb opening for the chain to attach? if so don't you thing doing the painting process orange over-spray would get on the top of the studs.
Yes I can see that happening , but figure a painter with a spray gun painting a engine block and valve covers and over sprays up to the lower intake bolts , but how you get small orange tab only on the tips , who knows it could be like your saying over spraying when painting the engine
4) None of the above.
Thanks.
Rick
Rick------
For engines with cast iron intake manifolds which were painted as part of the engine assembly, there was some sort of mask that was used to prevent the carb flange from receiving any paint. This mask may have also covered the carb studs. However, more likely, the carb studs were also protected by cardboard tubes, likely open-ended. So, when the engine was painted the tops of the studs also received paint.
