71 Oil on Carpet - NCRS Discussion Boards
71 Oil on Carpet
  • Donald K.
    • January 5, 2018
    • 11
    71 Oil on Carpet
    Help, I removed the floor mat an noticed it was damp. oily.. when I pushed down, the hole under the driver side, a oily substance came out. I also noticed lite oily feeling under the ash tray. any help would be appreciated.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 71 Oil on Carpet
    Donald, Could it be DOT 3 Brake fluid? Check the interior boot area around your Master Cylinder. Maybe take a sample and apply it a scrap painted item to see if it removes the paint. If it does, it's DOT 3.
    Rich
    • David H.
      • June 30, 2001
      • 1485
      Donald,
      Have you checked carpet and backing for “oil” up under dash? Oil seep from gauge?
      Dave
      • Donald K.
        • January 5, 2018
        • 11
        I just noticed it when I removed the floor mat.
        The oil is closer to where you sit then near the pedals.
        also some under the ashtray.
        • Donald K.
          • January 5, 2018
          • 11
          I will check to see it removes paint
          stay tuned.
          be back soon
          • Donald K.
            • January 5, 2018
            • 11
            I just checked on a painted surface. no luck. it looks kinds greenish, but I am wondering if it is from the carpet which is royal blue.
            I also opened the brake reservoir and it is almost full. with the amount of damp carpet, if it was brake fluid, it would be low.
            • Donald K.
              • January 5, 2018
              • 11
              I am taking it into a mechanic first of the week. could the oil gauge be leaking.
              • David H.
                • June 30, 2001
                • 1485
                Donald,
                From your description, oil is pooling at lowest point on floor. Any evidence on (under) carpet oil “wicked” from somewhere else - in particular from a source that also caused oil on ash tray?
                Dave
                  Donald------
                  If it's actually "greenish" it could be engine coolant from a failed heater core. The location you describe would be unusual for that but if there's quite a bit of it, I'd say that's the most likely.
                  • Scott O.
                    • December 9, 2009
                    • 100
                    Brake fluid (other than siliconeJ and antifreeze will mix with water. If the oily substance doesn'tmix with water, it is oil based.
                    Hope this helps.
                    Scott
                    • Donald K.
                      • January 5, 2018
                      • 11
                      This makes sense, because before I took delivery from Vanguard, they had to replace the heater core.
                      how can i determine if it is the heater core.
                      Come to think of it, sometimes when the care is started, I hear a gargle sound.
                      it is also on the passenger side but not as much
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11302
                        Donald, Check for traces of antifreeze in the heater ducts which point to the floor on both sides.
                        • Scott O.
                          • December 9, 2009
                          • 100
                          Good morning Donald,
                          Does the interior have a “sweet” smell? Does windshield fog up?
                          if so, most likely antifreeze - heater core
                          Scott
