After the 3/4 gear shift rod popped out from the transmission's forward lever on the highway (luckily, I was able to drive home in second gear), I'm figuring out the fasteners used on Muncie linkage.
UPC 7, sheet B3 of the 1970 AIM shows:
- 120394 "P. Washer" on the 3/4 shift rod's forward swivel. Is this something unique, or a common flat washer?
- 3749084 "Retainer" goes on top of the 120394 P. Washer. Is this is what some call a G-clip (photo)?
- 3709558 "Spring Washer" on the 1/2 shift rod's forward pin. Is this a thin, wavy washer? Or a common lock washer? I believe its purpose is to create a load/tension between the shift rod's pin and the transmission's shift lever.
- 103373 "C. Pin" goes on top of the 3709558 Spring Washer, attaching the 1/2 shift rod's pin to its lever. Is this a common cotter pin? If yes, just use the largest size that fits?
Thanks folks.
Thanks folks.
