I have seen bolts advertised with an "L" head, can anyone comment on whether these bolts could be correct and what C2 year would be applicable? Thanks
spare tire carrier mounting bolts "L" head.
Re: spare tire carrier mounting bolts "L" head.
Paul, there were many suppliers for mid year the spare tire carrier bolts, I have seen no head mark bolts, and RBW, E, I would also say that L was another. 5/16 x1" recessed hex head with a separate washer.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Paul
Photo would help. Are you asking about long bolts with four sided head consisting of two straight flats and two “round” ends?
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
Thank you sir. I've seen EW and D as well as the two you mentioned. I thought L were also used, but good to know. The 6th Guide only mentions E and EW. My fear is they will only credit the two mentioned in the guide.- Top
The head mark I see a lot on original cars is " D " with fine thread.- Top
Paul, those bolts likely do not have much point value. and most judges would except the repro bolts. if anything deduct there may only be 1pt., it all depends on the point value that the judge places on hardware, the hardware may also inc. the tub hanging hardware.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Carrier bolt + washer off my unrestored 1967, 45K miles, Jan 67 build, no head markingsAttached Files- Top
