C2 Power Steering Conversation - NCRS Discussion Boards
  • Robert C.
    • December 1, 2001
    • 46
    I am contemplating adding original power steering to my 64. I would appreciate feed back from members that have power steering for pros and cons. I have heard that C2's don't handle as well at higher speeds. I drive my cars, any info appreciated.
  • Harry S.
    • July 31, 2002
    • 5258
    Re: C2 Power Steering Conversation
    Have it in both my 63's, love it. No problem at 85 but I usually stay around 70 on the interstate.
    • Robert C.
      • December 1, 2001
      • 46
      Thank you I have heard it becomes extremely sensitive since it is as responsive at all speeds.
      • Peter M.
        • May 30, 2013
        • 358
        Robert,
        My 67 has power steering and it is a pleasure to drive. I don't find it overly sensitive. Tires, alignment and the condition of the suspension all play a big role. My car has Diamond back Michelin tires.
        Kind regards
          Robert------
          I ordered my 1969 without power steering. In 1986 I added original-type power steering. It is the best thing I ever did for the car. Period.
          • Robert C.
            • December 1, 2001
            • 46
            Robert------
            These comments are very helpful, really appreciated.
            • Timothy B.
              • April 30, 1983
              • 5177
              I also installed power steering on my 63 and 67 cars and I love it. Use a stock system and IMO you will be very happy.
              • Dick W.
                • 10483
                It's not the power steering that causes that problem. If you convert over, be sure to have the front suspension aligned to P/S specs
                Dick Whittington
                • Leif A.
                  • August 31, 1997
                  • 3607
                  And, I might add, to radial tires specs...if so equipped.
                  Leif
                  • Robert C.
                    • December 1, 2001
                    • 46
                    Should most alignment people know what that is?
                    • Leif A.
                      • August 31, 1997
                      • 3607
                      Courtesy of Duke Williams:
                      TOURING SETTINGS WITH RADIAL TIRES
                      Front camber: Zero deg.
                      Front Caster: Positive 1.5-2.5 degrees
                      (Power steering cars should go for the high end of the setting if possible. Some cars may be difficult to achieve 2 or more degrees.)
                      Toe-in: 1/32" per side (Note: if toe between front wheels is different, it will automatically equalize when driving, but this will cause the steering wheel to be cocked at an angle.
                      Rear Camber: negative 0.5 degrees
                      Rear Toe-in: 1/32" per side.
                      SPORT SETTINGS WITH RADIAL TIRES
                      As above with up to negative 1.0 deg camber at all four corners... also recommend urethane front anti-roll bar link bushings with these settings.
                      ALL CROSS READINGS SHOULD BE AS CLOSE TO ZERO AS POSSIBLE AND THE FINAL REAR THRUST ANGLE SHOULD BE AS CLOSE TO ZERO AS POSSIBLE.
                      If bias ply tires are installed use service manual toe settings for models originally equipped with bias ply tires.
                      Leif
                      • Greg H.
                        • 105
                        Hi Robert,
                        This post will help you.
                        https://www.forums.ncrs.org/showthre...power+steering
                        • Bill M.
                          • 1317
                          I have power steering in my 67 and manual steering in my 65. to tell you the truth I really cant tell the difference in either car. PS has radials and the 65 has reproduction bias ply tires. rarely do I go above 75MPH.
                          • Rick R.
                            • February 10, 2015
                            • 142
                            Great conversion conversation, lol.
                            • Tony S.
                              NCRS Vice President, Director Region VII & 10
                              • April 30, 1981
                              • 969
                              I love power steering on my 65. Be sure to attach it to the correct holes in your steering arms.
                              Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                              Original member of the Kansas City Chapter, est'd 07/11/1982.
                              Member: 1965 and 1966 National Judging Teams
                              Judging Chairman--Kansas City Chapter.
                              Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
