1967 L71 Spark Plugs - NCRS Discussion Boards
  • Gary C.
    • April 1, 1998
    • 375
    Gents,
    What is the recommended Plug for the L71, not cold climate . I have ACD N43XLS. They have been ok in the past. I now need a new set. The book says R43N. Are they available in the US?
    Gary
    Perth, Western Australia
    Re: 1967 L71 Spark Plugs
    Originally posted by Gary Cowans (30373)
    Gents,
    Gary
    Gary-----
    The AC 43N is no longer available from GM or ACDelco. Even the R44N is no longer available. You might be able to find a set of 43N on eBay if you want to go that far. I'd continue to use the plugs you are using if they perform satisfactorily.
      • 15610
      In general OE plug heat range spark plugs are too cold. Small blocks typically have heat range 4 and 3 for big blocks. Those who have dealt with these cars for decades have learned that heat range 5 is best for normal driving including long road trips for both engine types.
      Your car originally had the non-resistor 43N, but most non-resistor plugs have been discontinued. The best current replacement AC plug for your engine would be the R45XLS. If it's available in a non-resistor type (45XLS), use those.
      • Gary C.
        • April 1, 1998
        • 375
        Thanks very much for input.
