C2 Convertible Front latch - NCRS Discussion Boards
  • Joe T.
    • February 25, 2018
    • 153
    I have a 1966 Convertible. The pin on the front top latch fully engages on the passenger side. The pin when latched only goes in about half way on the driver side. The top and latches are tight on both sides. The top also appears straight while looking at it along the front windshield chrome. Is there any adjustment to make the latch (pin) on the drivers side to be fully inserted? Do I need a new latch? Is it the rubber seal keeping it from fully engaging? Is this common? I can't find anything in the Assembly Manual.
  • Alan D.
    • January 1, 2005
    • 2027
    Re: C2 Convertible Front latch
    The clamp seen on lower center is adjustable, sorry did not have a better picture.
    • Joe T.
      • February 25, 2018
      • 153
      How is it adjusted. I can't see where or find any information on how to make an adjustment.
      • Alan D.
        • January 1, 2005
        • 2027
        Two large screws on chrome latch, loosen and slide chrome latch up/dwn Be careful with screw so you do not mark them up.
        • Joe T.
          • February 25, 2018
          • 153
          It is adjusted up with no success. I noticed when unlatched on both sides the top has about a 1/4 inch gap on the driver side. Perhaps the whole top needs adjusted? Or, the inside chrome at the windshield driver side needs to come up?????
          • Michael H.
            • December 1, 1987
            • 724
            Latch the front of your convertible top first then latch the back part of your top last. If you have new weather striping this could interfere with latching.
            Mike
            • Joe T.
              • February 25, 2018
              • 153
              Tried it with no success. When unlatching the rear, the passenger side pin will be engaged without the latch. The driver side pin does not come near the the lower latching point without it being latched and a gap is noticeable between the top and chrome.. Also, with the rear unlatched the top seems to be on a twist to the right front. Can't understand why it will latch and the pin only goes in half way..
              • Joe T.
                • February 25, 2018
                • 153
                I have adjusted the top from the rear pins by moving the latch forward. Front is in all the way on passenger side and half way on driver side.
