inner fender paint - NCRS Discussion Boards
inner fender paint
  • Mel S.
    • August 31, 1992
    • 263
    inner fender paint
    What finish black is the inner fender, firewall, etc. for a 1966
    Mel
  • Ron G.
    • December 1, 1984
    • 865
    "SOLID LIFTERS MATTER"
    • Irby G.
      • November 1, 2001
      • 267
      Re: inner fender paint
      Can't remember where I read it...will need to do some re-research but Quanta makes a semi-flat black engine compartment paint.
      • Gene M.
        • April 1, 1985
        • 4232
        http://www.gastanks.com/System-5-Eng...tinfo/06%2D04/
        Magic paint at Tractor Supply is an enamel and a very close match to the description Ron spoke of.
        I find quanta paints many times woun’t spray out of the can. So I avoid them.
        • Ronald L.
          • October 18, 2009
          • 3248
          IFF the 1966 spec was Duco Lacquer, why are you telling people its enamel? A search of John's detailed paper on this should clarify.
          • Fred Y.
            • April 30, 2000
            • 319
            Mel, I have always used the Eastwood "under hood black" lacquer. Great coverage and just the right amount.of sheen.
            Plus it is lacquer as original.
            • Ron G.
              • December 1, 1984
              • 865
              • Brian K.
                • May 31, 2004
                • 358
                I have a couple gallons of the GM Black reconditioning paint, really great stuff fast dry and easy to blend for touch up's. Wish you could still get it.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  I am seeing several negatives on the Eastwood product reformulation being like water out of the can, not resistant to the basics, etc. I have the names of the DuPont to PPG tech transfer, now the search for that begins...
                  • Fred Y.
                    • April 30, 2000
                    • 319
                    I purchased a qt cannot the Eastwood and sprayed it from my gun during blackout. So far it looks really good.
                    • Brian K.
                      • May 31, 2004
                      • 358
                      If I didn't have GM Black paint I would use SEM Trim Black which you can buy in quarts and you mix it 50% Trim black to 50% lacquer thinner. But be aware since it's a lacquer product it can and will blush on wet or humid days. They also sell it in spray cans but the sheen just doesn't look right to me out of rattle cans.
