1962 corvette headers - NCRS Discussion Boards
  • Karl S.
    • September 18, 2017
    • 6
    Anyone have any information for a header application,i put a sbc 383 stroker motor with edelbrock victor jr ANGLE plug heads are there any bolt on headers or do I have to have them made.Thanks for any info you have.
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1962 corvette headers
    Why not start with Edelbrock?
    • Gene M.
      • April 1, 1985
      • 4232
      Hotrodders.com deals with modified cars on a regular basis and should have multiple suggestions
      • Bob W.
        • December 1, 1977
        • 799
        Karl, Take a look at Summit Racing or Jegs both sell headers.
        • Tom B.
          • March 1, 1978
          • 720
          I see your dilema. I just looked through a few of the big name header manufacturer web sites and don't see anything for C1 Corvettes. Also I don't see any refference to straight or angled plug for the ones listed for other Chevys. I have seen where some recommend the same header for C1s as used on the '55-'57 Chevys. I have never tried this. The Doug Thorley Tri Y headers would give extra clearance though. I used to run Tri Y back when and they made a lot of low and mid range power where your 383 will live most of it's life. I think your best bet is to contact the header manufacturers directly for thir recommendation and availability. Then shop price at the parts houses like Summit and Jegs. I have found some parts to actually cheaper from the manufacturer than a distributor. It's rare but worth checking.
          Tom
          • Karl S.
            • 6
            Thanks for all the information the hardest part is waiting on hold so long I hang up and call again later.
            • Bill M.
              • 1317
              Karl good luck! I got crucified by the commenters when I asked about putting headers on my 2015. It was very rare 1 of about 17,000 built. Seems we have come to our senses.
              • Terry D.
                • May 31, 1987
                • 2690
                Karl
                Hedman Headers and Hooker Headers still make headers for C1's. Not sure about the angle head application. I have Hedmans on my 62 with a 383 in it. Also have a Tremec 5-speed behind it. Makes for both street and cruising!
                • David H.
                  • June 30, 2001
                  • 1485
                  Karl
                  Welcome to Tech Board.
                  A few years back Super Chevy had a “Corvette Headers” issue (link below) that a least has a number of vendors. Especially note comments on fit. Helped with a 1972 body drop (big block) a couple of weeks back where owner insisted on side-exhaust headers running into a 5” collector. Looked nice, but fit to steering box / access to spark plugs / body clearance /etc was problematic. These headers could only be installed with body off. I know you’re not talking about side exhaust - point is give consideration to vendor comments for ease of fit, clearance, access to spark plugs, etc.
                  Dave
                  Have you ever tried exhaling through a straw? It's not the easiest thing in the world to do, is it? The full power of your lungs is held back as you attempt to
                  • Karl S.
                    • 6
                    early as they go 1968
                    • Karl S.
                      • 6
                      another forum said the hookers would work with short plugs,the motor came with hooker pro comp headers for a 69 Camaro ill see if I cant customize them
                      • Richard G.
                        • July 31, 1984
                        • 1715
                        For years I had a set of Tri Y headers on my 57 Corvette with angle plug heads. Tubes were close to the spark plug boots but they worked. Don't be afraid of denting the headers. I used the round end of a pall-peen hammer and hit it with another. That way I didn't miss. There is a great header basing YouTube video by Engine Masters. They beat the heck out of the header with very little loss of HP. A fun watch if nothing else.
                        • Roger W.
                          • January 29, 2008
                          • 564
                          Corvette Central Has a complete exhaust system for C1's with headers. I don't know if the headers are sold separately. I have set of Jardine 4 tube headers on my 59. They hang below the frame, so a little ground clearance is lost.
                          • Terry D.
                            • May 31, 1987
                            • 2690
                            Kari
                            Summit Racing has Hooker and their own brand for 62 Corvettes, it appears Hedman is no longer making C1 headers
