I'm researching the proper exhaust manifold fasteners for C3 big blocks.
In this thread, Terry talks about "tri-lobe locking fasteners" used on the outside exhaust manifold cylinders.
https://www.forums.ncrs.org/showthre...light=tri-lobe
In these threads, Joe says this bolt is GM #3909821, and has a "LOCKING THREAD design. In this design, the minor thread dimension (i.e. the bottom of the thread "grooves") is increased by a small amount, thereby making the bolt an interference fit."
https://www.forums.ncrs.org/showthre...manifold-bolts
https://www.forums.ncrs.org/showthre...d-French-Locks
Questions:
- Is GM #3909821 used only on the outside hole for cylinders 1, 2, 7, 8 for a total of four bolts per engine? Or are they used on both holes for these cylinders for a total of eight bolts? (I understand cars with AC or PS use studded bolts which replace one or two of these bolts.)
- How are these bolts designed? Terry's "tri-lobe" description seems different than Joe's description of shallow cut interference threads. I want to understand what I'm looking for when I order these.
Questions:
