Balancing 67-82 wheels with trim rings - NCRS Discussion Boards
  • Tim S.
    • May 31, 1990
    • 697
    Has anyone ever done a static balance (inside of wheel) with the trim rings installed? I'd have to think the weight of the ring and the clips could effect balance.
    Tim
    • 15610
    Re: Balancing 67-82 wheels with trim rings
    If you just want a static balance with weights on the inside there's no reason you can't have the trim rings installed, and it would be a good idea. If they ever have to be removed, getting them properly indexed again is automatic since you have to line up the hole with the valve stem.
