Had the motor on my 71 LT-1 rebuilt. Car ran fine on the dyno. Now engine back in the car and it misfires and can't be timed. Only difference between dyno and now were different plug wires and a regular distributor--didn't use TI on dyno.
Plug wires replaced still misses and timing can't be corrected when rotaing the distributor. Problem has to be in the TI system.
Distributor, coil, and amplifier box sent to Dave Fiedler to be checked out-all ok.
TI harness replaced with a new one from M & H fabrication per Dave F. recommendation.
Voltages all check out and all grounds with cleaned and reconnected.
Car starts but you get popping (carb used on the car when dynoed was fine and was just rebuilt) and the car runs like crap/misfires
Is there a capacitor on the coil in 71 TI system? If bad could that cause a problem.
Any suggestions--have measured voltages and 12V to TI system.
Thanks--have run out of ideas and parts to replace.
Paul
Paul
