1966 BB Fan Shroud Rivet? - NCRS Discussion Boards
  • Jim S.
    • March 13, 2013
    • 360
    Trying to help a friend restore a 1966 427. The 66 TI and Judging Guide says to look for a rivet that is used to hold two of the sections of the fan shroud together. They are normally bonded BUT it is unclear if a rivet was also used. Some say it was a factory 'addition', some say it was a post assembly 'fix'. What say thee?
    Factory? TSB? Assembly line fix? "Bubba" fix? Thank you.
  • Russ S.
    • April 30, 1982
    • 2161
    Re: 1966 BB Fan Shroud Rivet?
    Rivet was factory installed.
    • Jim S.
      • March 13, 2013
      • 360
      Russ, Do you think this began in 66 and was on all BB's?
      • Russ S.
        • April 30, 1982
        • 2161
        I have seen it on original BB. Weather or not it was on all BB I can't say.
        • Jim S.
          • March 13, 2013
          • 360
          Right, that the concern. Was it installed on ALL BB shrouds? Would hate to install in on a NOS shroud to then find not all of them had it on the assembly line.
