What is the correct location for the engine lift brackets on a 1970 Corvette 350 engine with automatic transmission? The judging manual indicates the location for both brackets for a 350 with manual transmission, but not for a 350 with automatic transmission. Are the locations the same?
Location of engine lift brackets on 1970 small block with automatic transmission
Re: Location of engine lift brackets on 1970 small block with automatic transmission
Front location (driver's side front bolt or front 2 bolts on intake -- depending on the year of your Corvette) is the same regardless of transmission. Rear bracket is not present for M40. I wish I knew how they lowered the engine/transmission into the chassis for M40 without a rear bracket, but some things are a mystery.What is the correct location for the engine lift brackets on a 1970 Corvette 350 engine with automatic transmission? The judging manual indicates the location for both brackets for a 350 with manual transmission, but not for a 350 with automatic transmission. Are the locations the same?Terry- Top
