1966 Base 327, AC, PS which alternator pulley fan - NCRS Discussion Boards
  • David P.
    • May 26, 2009
    • 16
    I've got a 66 base 327 with AC & PS trying to determine which alternator pulley to use, car was built 12/65. Not sure whether to use 3875968 or 3909817, both appear to be the relatively the same size.
    Thanks!
    Other pulleys are:
    Crank - 3850838
    Crank add on - 3751232
    Water pump - 3890419
    PS - 3770509
    Re: 1966 Base 327, AC, PS which alternator pulley fan
    Thanks!
    Other pulleys are:
    Crank - 3850838
    PS - 3770509
    David------
    I believe it would be the GM #3875968. For one thing, the GM #3909817 which did eventually succeed it, did not exist as early as 12/65.
    • David P.
      • May 26, 2009
      • 16
      Thanks Joe! I kinda assumed it was probably the 3875968 as that's what the judging guide states, but there is just a lot out there about both types.
      David
