Rear wheel bearings for C2s?
Re: Rear wheel bearings for C2s?
"GM specifically cautions that no attempt should be made to adjust the thickness of the shims."
I understand you are just passing on GM information and not judgment.
What could the possible logic be behind the caution?
I would bet the ones I grind are flatter and more accurate than the stamping they made them from?
What are they cautioning against, putting them on a steel plate and massing them thinner with a BFH?
Difficult to understand the caution is all I am saying.
Rick- Top
The bell spacer in every arm I take apart is out of parallel up to 005", I parallel grind them. The shims come in sizes too wide to dial in the spec's I am looking for so I final grind shims within a few tenths to get them where I want. All the parts go together flat and tight and the dial in doesn't change from setup tool to final install.
Now with that said, seeing how some rebuilders set up rear bearings - professional or DYI- I can understand GM's statement. However, correctly done there is no issue, same for fitting a solid pinion sleeve in place of the stock crush sleeve.- Top
If you don’t have the resources of Gary to custom grind, there are tooling shims available in correct diameters (within a few thousands bigger) in increments of .001 or less. They are hardened and should get you the stack up to zero clearance the taper roller bearings. I don’t recall the web site but some investigation should get you there. They were perfect for my cars in obtaining zero clearance.
Those tooling shims in combination with the available shims from Corvette jobbers should get you a perfect fit. Be wise and check all the Corvette jobber pieces for precise dimensions and squareness/parallel as Gary advises.- Top
Rick------"GM specifically cautions that no attempt should be made to adjust the thickness of the shims."
Rick
My thought has always been that the shims are case hardened, not through hardened. So, by adjusting them the case hardening is lost, at least on one side.
One other thing: a lesson that I learned a long time ago is that when GM specifically cautions about something, there is usually a good reason for it. They most often don't state what the reason is but if one does not observe it, one may suffer the consequences.In Appreciation of John Hinckley- Top
Rick------
But realistically when the bearings are shimmed correctly and tightened down torqued as they should be there is no relative motion of the shims and sleeve relative to anything that would wear. Everything creating the bearing fit is torqued up solid and cotter pinned. Certainly a shim or sleeve out of square/parallel is worse than the surface ground true a bit into case hardening.- Top
