Steering Column washers - NCRS Discussion Boards
  • Russell J.
    Infrequent User
    • October 16, 2014
    • 6
    1967 convertible
    I recently discovered a washer seemed to be missing putting the column back. For lack of a better term there is a wavy washer and a c clip that needs a washer between them that I am having difficulty finding. Is there source for this washer or is a standard washer and if so what am I looking for?
    Russ Posthauer rtp67vette@gmail.com
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Steering Column washers
    Originally posted by Russell Posthauer Jr (60570)
    1967 convertible
    Russ do you have a first or second design. There was a change in the steering column loading design.
    I’m not sure but there may be photos in the new manual showing the differences.
    • Russell J.
      Infrequent User
      • October 16, 2014
      • 6
      The car was built in June so I would assume it would be the second design
      • Stephen L.
        • May 31, 1984
        • 3148
        Russell,
        Here is a photo (APRIL 67 build) of the washer and associated parts in question. Appears to be a flat washer but not something you'd find at the hardware store.
        Try Richard Fortier as a source... he has a lot of small items such as this.... He advertises in the DRIVELINE.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          I'm taking a wild guess here.
          LI Corvette 18-21D Wave Washer,thrust Washer & Clip For Upper Beari 1967 REGULAR AND TELE
          • Russell J.
            Infrequent User
            • October 16, 2014
            • 6
            Thank you for your response
            • Russell J.
              Infrequent User
              • October 16, 2014
              • 6
              Thank you for the response
              • Gene M.
                • April 1, 1985
                • 4232
                Try Rotoclip.com
