C2 differential Shims - NCRS Discussion Boards
  • Frank B.
    Infrequent User
    • 2
    I am upgrading from a open diff to a posi unit and need additional shims to set up the rear. The early C2 uses individual shims not a pack. They were available in increments of .002 from .064 to .094. Does anyone know of a source for these.
    thanks
    FRANK B
  • Richard G.
    • July 31, 1984
    • 1715
    Re: C2 differential Shims
    Check out Randy's Ring and Pinion
    Shop RANDYS Worldwide for premium suspension, differential, and remanufactured drivetrain parts. Discover expert support, top brands, and performance upgrades built for strength, reliability, and adventure.
    The link is for an adjustable shim pack. It is held captive by the two outer (thicker) shims.
    I have used them with good success.
    • Frank B.
      Infrequent User
      • 2
      Thanks. Will call
        thanks
        FRANK B
        Frank-----
        The PRODUCTION-type cast iron shins were never available from GM in SERVICE. In SERVICE GM only offered a spacer + shim sets. However, all of these are long-since GM-discontinued. So, something like what has been suggested by Richard is "the only game in town" now.
        • Gary R.
          • April 1, 1989
          • 1796
          I think you will find the super side shims too thick to use, unless you have access to a surface grinder. The individual ones are too thin to get into place.
          I have a good selection of the stock steel thin shims I gathered over the years( not for sale ) that I use or machine to fit. You might find other model shims are similar and might work but I don't know of a kit sold in these specific sizes.
