1955 front cross mount behind water pump - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 670
    When i put the mount behind water pump it hits the rectangular casting hump on the head?? any help appreciated thanks RDR
  • Wayne L.
    • September 30, 1981
    • 233
    Re: 1955 front cross mount behind water pump
    Is the head a Tonawanda casting?
    • Ronald R.
      • May 31, 1989
      • 670
      I will check, it is dated and cast correctly
      • Joe R.
        • July 31, 1976
        • 4547
        Ronald,
        Here's a pic of a 55 pad that shows the motor mount behind the water pump. Unless your trying to put the motor mount on backwards it is impossible to have interference with the head.
        JR
        • Ronald R.
          • May 31, 1989
          • 670
          no casting info is viasble
          • Ronald R.
            • May 31, 1989
            • 670
            This side is easy!! The casting hump on the other side is about 1/8" to high for the mount to fit, possible just a casting flaw as the other head has a smaller hump. thanks RDR
            • Ronald R.
              • May 31, 1989
              • 670
              Here are some better pictures. It might work if I switch the heads to the opposite side. thanks RDR
              • Dan P.
                • December 1, 1990
                • 683
                The Tonaowanda head the front rectangular pad is thicker.Try and measure how much it sticks out .I think I have a 55 head to compare it to .
                • Jim D.
                  • 2882
                  Corvettes used Flint heads that had the front casting machined down to approx. .060 for this exact reason. Tonawanda heads, which you have, were used in other applications that didn't require the machining process. Here's a pic. of my 1960. You can easily see that a Tonawanda head wouldn't work.
                  • Ronald R.
                    • May 31, 1989
                    • 670
                    I switched heads from one side to the other and all fit well. thanks for the help. RDR
                    • Mike M.
                      • May 31, 1974
                      • 8365
                      if the head is a tonowanda casting, the judges usually detect the "sand cast" appearance of the rectangle(vs the broached surface of the rectangle on a flint head).you could also pull the valve cover and if the casting date year is two numerics, then its a tonawanda head. mike
