One problem I see is with the door closed there is not access to the top hinge bolts, except maybe two. Can tightening the bottom hinge bolts hold the door in the correct position long enough to open the door and tighten the top hinge bolts? Do you use any sort of shims to hold the door in the correct position while tightening the hinge bolts?
Any help is greatly appreciated.
