Are the pins and bushings sold by LIC a good fit. The ones I got from the local auto parts store are the wrong sizes.
C2 door hinge bushings and pins
Re: C2 door hinge bushings and pins
They were available from GM and probably still are. I got a set from a Cadillac dealer some years ago. They used the same size bushings and pins for many years across all GM lines. The new pins I received were about 1/4" longer than the original so I ground them down to the original size the bushings fit fine.- Top
Keith------
Pin and bushings are available from GM under replacement part numbers:
pins------GM #20046147
bushings-----GM #9721917
The pins need to be shortened which is easy.In Appreciation of John Hinckley- Top
