After fixing my washer pump, the tube came lose from the arm. How does one attach the plastic clips to the arm and tube? Is there a preferred method to reattach the tube to the tab on the right side (passenger side). Looks like it was soldered before, but hard to tell.
70 wiper arm washer tubes
Re: 70 wiper arm washer tubes
Here are some pictures of the wiper arms showing the clip locations from my 73. They are the same on your 70. The diagram is from Paragon's parts catalog also showing the clip locations. Four clips on the passenger side and three clips on the driver side. BTW, if you are a little hesitant about using the propane torch to re- solder as Russ suggests try using a daub of Locktite Superglue Gel in that same area to hold the tube in place. That's what I use when I break mine loose every time I accidentally catch it on a towel when cleaning/ washing the car
Hope these help.Jimmy
1973 Convertible
L48,M20,N40
Mille Miglia Red/Oxblood
- Top
