1960 Engine - NCRS Discussion Boards
1960 Engine
  • Don H.
    • December 1, 1981
    • 1482
    1960 Engine
    I have a friend looking at what appears to be a 1960 passenger car block. Numbers are: casting 3756519; date D 13 0; assembly F04I4DB. The question is since it is a passenger car block, is there any way to tell it is different from a Corvette block other than the pad assembly stamping? Thanks, Don H.
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1960 Engine
    To the best of my knowledge, as a "Flint" block, it "could" have been built as a Corvette engine.
    • Tom D.
      • September 30, 1981
      • 2126
      Re: 1960 Engine
      The casting date format for a Tonawanda block has two digits for the year, but I don't know if they made small blocks in NY that long ago. I think this block would look just like a 1960 Corvette 283. I will look for some photos.
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
        Re: 1960 Engine
        Tom-----
        They did cast blocks at Tonawanda that long ago. However, this is a Saginaw-cast block since it was machined and assembled at Flint.
        Externally, this block would be identical to a block of the same casting number used on Corvettes.
