66 Coupe Transmission - NCRS Discussion Boards
  • John F.
    • July 31, 1999
    • 105
    I've got a 66 coupe with a problem I've not run into. The transmission is a muncie 4 speed and it shifts very well through all the forward gears. When I attempt to get into reverse, I seem to be locked out. It works intermittently, but usually I have to double clutch, inch forward an inch or two, and generally takes a few minutes to finally get it into reverse. I'm thinking maybe the Hurst shifter is out of whack or something along those lines. Any advice?
    John Farren
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: 66 Coupe Transmission
    Sounds like a readjustment of the shifter linkage is in order..... check for excessive wear of the holes in the arms and wear on the rods which could cause slight misalignment.
    • Donald H.
      • November 2, 2009
      • 2580
      I would also suspect the rod adjustments. Is this something that just started, or been this way since the shifter was installed?
      i had an issue with my 67. It would shift fine through the forward gears but grind with reverse. What fixed mine was readjusting the clutch linkage.
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
