Wittek 1 1/6" Tower Clamps - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    Will the 1 1/16" tower clamp work for both 5/8 and 3/4" heater hose. The size sounds correct but doesn't look right that it would fit the 3/4" hose. Thanks.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • 15573
    Re: Wittek 1 1/6" Tower Clamps
    If by "work" you mean prevent leaks; the answer is "maybe" depending on the wall thickness of the heater hose you are using.
    If by "work" you mean pass judging; the answer is no.
    • Jack C.
      • 1090
      Ah! The 1 3/16" is used on the 3/4" heater hose. The 1 1/16" is used on the 5/8" hose. It pays to read the Guide.
      Jack Corso
        • 15573
        Please also note the configuration (besides size) differences on the clamps. 1 1/16 claps are dated and 1 3/16 is stamped DCM. I haven't looked at the TIM&JG ina while, but I believe it explains the meaning of DCM and the finish. If necessary I will check my memory, but family Holiday events are upon me now.
