'63 L84 spark plug - NCRS Discussion Boards
'63 L84 spark plug
  • Michael J.
    • January 27, 2009
    • 7073
    '63 L84 spark plug
    Which AC plug did a '63 L84 engine leave St. Louis with? Thanks.
  • Rick A.
    • July 31, 2002
    • 2147
    Re: '63 L84 spark plug
    Michael - believe would have left with AC-44's
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • John D.
      • December 1, 1979
      • 5507
      Michael, The 44 plugs are too cold today. Use AC 45 or 46. John
      • Rick A.
        • July 31, 2002
        • 2147
        ChePhart agree they are too cold today, but the question was what did the vehicle leave St Louis with - AC-44's like I stated
        Rick Aleshire
        • Michael J.
          • January 27, 2009
          • 7073
          I have 46s for driving, but that takes a hit on judging points, so needed the TFP plug, and I assume the green stripe version too. Thanks Rick.
            • 15610
            Essentially all small blocks from the late fifties to '68 had the AC 44 from the plant, replaced by R44s for '69. I believe there might be some cosmetic differences over the years, and the various year JGs should have the details. The 44s kept fouling in my 340 HP SWC, so I finally installed 45s, which mostly solved that problem, and I installed 43s when I went out to Kent for a day of hot-lapping, and they were just right for that type of service.
            • Michael J.
              • January 27, 2009
              • 7073
              Thanks Duke. That brings up a question for you, I have a couple of sets of R43-XLS AC plugs, are those way too cold for normal driving?
                • 15610
                Those are big block plugs (resistor type) that are modern substitutes for the 43N that was standard in early big blocks, but they're too cold. R45XLS would be a better choice. For all OE engines AC heat range 5 or equivalent in another brand are the best choice for the light duty use that most vintage Corvettes see today.
                • Michael J.
                  • January 27, 2009
                  • 7073
                  Thanks Duke, that's what I was afraid of, more stuff for the trash........
                  • Rick A.
                    • July 31, 2002
                    • 2147
                    agree with Duke any AC 45 plugs or another brand that is heat range equivalent will work just fine - something like a Denso W14U or NGK XR4 or maybe even Bosch
                    Rick Aleshire
                      • 15610
                      In the NGK line, the B4 is a better choice because it's a non-resistor type, and I think the Denso W14-U is the best choice if you don't need to run AC plugs for judging because it has their "U-groove" ground electrode, which offers more sharp edges for spark propagation. These are small block plugs. Off the top of my head I don't have the number for big plugs, but they would also be heat range 14 and 4 respectively.
