Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Enclosed carhauler -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
First trailer I purchased there had over 250,000 miles on it when I sold it. I replaced one rivet, tires, brakes, etc is all that was all the maintenance it required. Had as much as 12,000# in it at a time.
Mr. Whittington, thank the Lord, I've got about 20,000 miles of trailering in my slope nose and never had any issues. For the money, you can't beat TWI trailers.
Keep in mind, you might have good success with a used enclosed trailer. We've owned two used enclosed trailers (bought them from fellow members).
Currently using a 1998 Wells Cargo trailer. Did plenty of upgrades to ensure it was mechanically sound (bearing and seals, brakes, tires etc). Value wise we're ahead of the game and have also installed the goodies we want. With new mechanical and wear components, the biggest factor in the useful life of the trailer is rust. Otherwise with basic maintenance and care it will last.
One other point. Make sure you measure the wheel well on the left side door to ensure the door on your Corvette will open. Some wheel wells are too tall and you won't be able to fully open the door.
You should consider a Trailex enclosed trailer. It is extremely high quality and very light! You can tow it with an SUV. I have trailered my car over 15,000 miles in my Trailex and wouldn't own anything else! Also consider that Trailex is a long time supporter of NCRS and a very faithful advertiser. You will be really happy at resale time!
Best of luck with your search!
