I read a past post regarding the amp gauge. It cautioned: "On shorting, you do not want any ohmic contact between the ammeter posts and the instrument cluster." I do not know how to check for this.
In anticipation of removing the amp. gauge, I removed the nuts from the ammeter posts. I was not able to move the cluster forward enough to remove the amp.gauge. I decided to put things back as they were. I refastened the cluster, refastened the nuts to the ammeter posts and reconnected the amp gauge. Upon starting the car, the amp.gauge pointed down to 6 rather than straight up to 12. It now alternates between these positions every time I restart the car. If it points up to 12 when you start the car, it will point down to the 6 position the next time you start it.
I have not been able to find any crimped wires from refastening the cluster. I am wondering if I shorted the ammeter posts to the instrument cluster when I refastened the ammeter posts.
Any help or suggestions would be appreciated. Thanks.
